rePhase 1
Re: rePhase 1
Messagepar thierryvalk » sam. 10 déc. 2016 11:05
Et la version 1.2 :)
https://sourceforge.net/projects/rephase/
  New features:
    - REW automated EQ settings generated using the 'rePhase' equaliser
      type (as implemented in REW V5.17 beta 14 and up) can now be imported
      directly into a paragraphic EQ bank
    - EQ points in paragraphic EQ tabs can now be individually bypassed
    - added a "tools" menu in paragraphic EQ tabs, effective on current
      bank:
      * load/save current bank into a '.eq' file as a JSON object
        (gain paragraphic EQ tab only)
      * load/save current bank into the clipboard as a JSON object to
        easily copy it to other banks or rePhase instances, or share it
        through forum posts
      * import REW EQ settings generated with 'rePhase' equaliser type
      * convert back and forth between constant and proportional Q types
      * invert corrections
      * bypass or activate all EQ points
      * order by frequency, active or reversed order
    - "Help" menu entry (albeit probably not very helpful :( )
  Bug corrections:
    - The long lasting encoding issues with paths when loading, saving, and
      generating files should now at last be solved. It was already
      supposed to be the case in version 0.9.7, then 1.1.0, and should now
      *at last* be effective. Please report any problem with files or paths
      containing special characters (accents, etc.).
    - Corrected a bug introduced in version 1.1.1: fader position could
      sometimes change based on the position of the mouse cursor after
      loading or saving a file
    - Stop confining mouse cursor within faders, as it could stay stuck
      under some rare circumstances
  Adjustments:
    - set default optimization setting to none, as optimization process can
      increase preringing and should only really be used when the number of
      available taps is too limited to obtain the desired magnitude curve
    - increased default number of taps to 16384 to reflect an increase in
      CPU and DSP power in the last years (wishful thinking? :) )
    - boost FFT length calculation ratio to improve precision
    - changed default windowing algorithm from rectangular to hann for a
      more generic default behavior
    - EPS vector files screenshots including result curves are now
      significantly lighter and result in smoother curves compared to
      versions 1.1.0 and 1.1.1
    - suppressed flickering when switching between Views buttons
    - default to "Large" view mode
On peut demander à REW de créer des EQ de correction en automatique et les importer dans rePhase.
Pouvoir mettre des corrections en Bypass me semble bien pratique et va faciliter la mise au point lorsque l'on fait des mesures en plusieurs étapes.
JSON, on en avait parlé avec Pos il y a bien longtemps; moyen relativement simple de partager des données entre deux softs.
Dommage que l'on ne dispose pas de l'ensemble des données chaque fois que l'on génère une Impulse. Cela permettrait de sauvegarder ces données rePhase avec le projet DStudio.
Re: rePhase 1
Messagepar thierryvalk » lun. 12 déc. 2016 17:38
L’intérêt est limité, mais il sera aussi possible de transférer des EQ de DStudio à rePhase.
Cela permet d'appliquer des corrections en temps réel dans DStudio et ensuite de les transférer dans un Preset de rePhase.
Faudra alors ne pas oublier de les mettre en Bypass dans DStudio.
